pmmsdn
September 14, 2024, 5:51am
1
This is mostly for sys-net and sys-usb.
I did look through the forums but nothing seems to get to the point. How do you set a password on the template VMS, sys-net and sys-usb if nothing else. If you cannot, why?
What if you want to connect to open WIFI at an airport or plug in your laptop to a hotel ethernet port?
Hi, if you had set your sys-usb and sys-net vms as disposable which is based on default-dvm; password will not be saved after a restart.
kenosen
September 14, 2024, 7:56am
3
Qubes OS - Disposable sys-net - Automatically connect wifi
0 - Description
This guide aims to answer to the (reccuring?) question:
How can I make my wifi connection remember my password?
In the “Configuration file” main section, you have 3 methods.
In the “RPC service” main section, you have an example of how to store your wifi credentials outside of the disposable template.
1 - Configuration file
1.1 - Copy the config file
Connect to your wifi with the Network-Manager panel icon.
Once c…
For the hotel or airport login, you’ll need to launch a browser (I.e. Firefox) from within sys-net
