tanky0u
December 27, 2021, 3:22pm
1
I am trying to run suckless terminal (st) on my debian-10 based personal qube.
I installed the stterm using the apt package manager on the debian-10 template.
Then I modified the /usr/share/applications/st.desktop file as follows:
[Desktop Entry]
Version=1.0
Type=Application
Terminal=true
Name=st
GenericName=Simple Terminal
Comment=Suckless (Simple) Terminal
Exec=st
However, when I run personal: st program from dmenu, I get two terminals getting spawned as follows:
The left hand side terminal is the normal debian terminal spawning the simple terminal on the right hand side.
I have tried changing the “Terminal” entry to “false” which, didn’t change the fact that again the gnome-terminal first got spawned and then the suchless terminal.
How do I get ONLY st getting spawned when I run on the dmenu personal: st?
Did you re-run qvm-sync-appmenus after fixing the st.desktop file?
Did you restart the personal VM after fixing the st.desktop file?
tanky0u
December 27, 2021, 8:05pm
7
Iambchop:
Edited st.desktop in template to set Terminal=false
Shutdown template
Started personal
Launching st, no longer has extra terminal
Interesting. I remember doing the “Terminal=false” thing and then restarting, and trying again. It hadn’t worked.
But I will try again and report back. Thanks.
tanky0u
December 28, 2021, 1:32pm
8
That’s puzzling that now what you proposed has worked.
I put the Terminal=false, and then did qvm-sync-appmenus debian-10.
And then shutdown the debian-10 template.
Then from dmenu prompt, selected my personal: st program to start.
And now it doesn’t spawn a gnome-terminal first. It now spawns just the suckless terminal (st) which is what my expected behavior is.
Thanks for the help.
