How to rename devices on (transient, DVM) sys-usb
hello,
i am looking for a way to rename the devices - as they appears on the WIDGET (usb icon)
I am finding very confusing to have these random strings
is there a gui that allows for the renaming of these - or a config file in the DVM on which sys-usb is based on ?
Thanks
Well, those are not really random strings, they are a combination of the Manufacturer’s name and USB ID strings/numbers; their role is to “uniquely” (or close to…) identify each device.
I am not aware of any rewriting mechanism, but it is conceivable to write an udev hook to translate particular device IDs to whatever you want.
For example, instead of SanDisk-AC00F-FEE0 to “My-Private-USB-stick” or so.
Again, you have to write it yourself…
thanks @barto
would these udev rules be edited / created /modified in sys-usb or in dom0 ?
In sys-usb.
If you have sys-usb, all(**) the USB hardware is connected to it.
__
** “all” meaning the PCI devices connected to sys-usb; you are allowed to have more than one “sys-usb” too, or connect one USB controller to sys-net, etc.
