I installed Qubes with a persistent wifi connection. After installation, I just entered my password in the network I wanted to connect to, and vuala, wifi works. The problem is that wifi is no longer needed since I’m using a hardwired connection instead. So after every boot, wifi autoconnects the wifi network I first logged onto after installation. I no longer want a wifi profile. So how can I remove a remembered wifi network from Qubes so it no longer connects to wifi on boot?
- right click on the network systrem tray icon
- edit connections
- click on the wifi network
- click on the
icon - validate
