How to remove phantom process?
thought there wold be more topics about this i dont see them
Fresh install of 4.3.1, after shutting down everything is crazy unresponsive. i did another install (also 4.3.1) and didnt update the qubes and the same problem
someone suggested it could be phantom processes and un-synchronized LVM structures in dom0 (im not a pro)a
another said a fresh install could have changed settings in order for it to work but after a shut down the changes are reset
dont know the solution to either
what do you think?
Doctors once suggested to blow tobacco smoke into rectums to possibly revive patients …
How about some qualified statements and explanations?
i3-1315U cpu and processer from intel, 16gb of ram, framework 12 (2025)
first session on a fresh install works fine, second one ui is buggy (doesnt show up or show where its supposed to) touchpad (not external) makes the cursor fly to the riight offscreen, the touchscreen works but you have to wait an entire minute for anything to respond
i thought the updates where the problem but i tried shutting down and logging in again on a fresh install but got the same results
what do you suggest?
let me know if you need more info
sudo lvremove /dev/qubes_dom0/vm-sys-usb-volatile
this command worked once but when you log back in its broken again (takes years for the terminal to open)
asked r/techsupport and someone told me just to turn it on and it started working computers are not real :skull:
