I have a VM with 200 MB private storage max size but it doesn’t need that much space. When I try to reduce the size it just jumps back to 200 MB. The VM is shutdown. How can I change it?
thanks
thanks
Ok so it doesn’t matter how big the max storage size is I get it. When I look at the Total Disk Usage widget I can see that I have 147 GB free out of 370 GB. However, my disk is 500 GB. Do you know why Qubes isn’t recognizing the full disk size?
