I accidentally use Firefox with the default DVM template. Is it possible to prohibit browsing like with the Whonix DVM template?
Is setting the net qube to none an option?
Remove web browsers in this template
Compartmentalize and set none for default netVm qube. I have over 100 qubes for different tasks.
It looks like @kzlz is asking if a popup can be displayed instead of the installed browser when it is launched in the dvm template instead of an actual disposable.
Run these commands in your disposable template terminal:
mkdir ~/.local/share/applications/
cp /usr/share/applications/firefox-esr.desktop ~/.local/share/applications/
sed -i "s|/usr/lib/firefox-esr/firefox-esr|/usr/local/bin/firefox-esr|" ~/.local/share/applications/firefox-esr.desktop
cat << 'EOF' | sudo tee /usr/local/bin/firefox-esr > /dev/null
#!/bin/bash
#Not running in Template.
if test -f /run/qubes/this-is-templatevm ; then
exit 1
fi
#Not running inside Qubes DVM Template.
if echo "$(qubesdb-read /name)" | grep -q "\-dvm" ; then
exit 1
fi
/usr/lib/firefox-esr/firefox-esr "$@"
EOF
sudo chmod +x /usr/local/bin/firefox-esr
But it’ll only work if your disposable template name ends with -dvm.
it worked. thank you. could you explain what i did?
The applications in Qubes OS menu are calling the associated desktop files in the qubes.
So when you start the the firefox app using Qubes OS menu it’ll search for desktop file named firefox-esr.desktop and will run it.
The firefox-esr package is installing the default desktop file in this location:
But you can override this desktop file by placing the new desktop file with the same name in the user home directory:
The files in user home directory will have precedence over default system files in /usr/share/applications.
Then you create a script that will check if it’s running in a template or in disposable template and will run firefox binary only if it’s running in AppVM/DispVM.
And you change the ~/.local/share/applications/firefox-esr.desktop so it’ll run this script instead of firefox binary directly.
Wouldn’t be more effficient to check for template_for_dispvms True pref than to check for qube name?
You can’t check it from inside the qube.
I thought something like this?
[user@dom0 ~]$ qvm-tags my-dvm add template_for_dispvms
Then, to put in 30-user.policy
qubes.OpenInVM * @tag:template_for_dispvms @anyvm deny
At least looks more like Now You’re Thinking With Qubes
I think, as @XMachina said, the OP wants to disallow the browser start in the disposable template qube itself. E.g. when you open it using Qubes menu Q → TEMPLATES → default-dvm → Firefox ESR.
Yes, you are absolutely right. I just thought that actually nothing should be executed in any (kind of) template. At least I’m following that logic.
