How to open terminal in VM using qvm-run
Hello qubes community,
I’m wondering if it possible to run the terminal using the qvm-run command.
e.g. qvm-run qube xfce-terminal
Thanks
Have you given it a go? On my Fedora 32 AppVMs xfce-terminal isn’t
installed, but either xterm or gnome-terminal work.
Have a look at the -p flag to qvm-run. That will give you the
commandline output for what you are running. Should tell you if there is
some other issue stopping it.
Im also using fedora and gnome-terminal is the command I was after!
Being a noob it slipped over my head after typing in 50 different variations of the word terminal.
For the xfce terminal when using whonix the command is xfce4-terminal
Thanks Jarrah!
If you use the -p flag to qvm-run, then you will see any output from
the qube.
In this case you would have seen the helpful message - “command not
found”
Always useful for debugging.
qvm-run domU qubes-run-terminal
