I installed Skype on debian-11 template, but its data is not persistent, unlike other programs. I always have to login again on Skype and go through 2FA every time I launch the appvm. I suppose I must use binddirs to make its data persistent but how do I know which folder I need to add on binddirs?
It’ll likely (but not necessarily) be store in /etc so that’s a good place to start from.
ls -aR /etc | grep skype
You can get creative with grep. If you can’t find anything there try:
sudo ls -aR | grep skype
Then in your AppVM:
sudo mkdir -p /rw/config/qubes-bind-dirs.d
echo "binds+=( '<dir>' )" | sudo tee /rw/config/qubes-bind-dirs.d/50_user.conf
Mind the spaces within the parenthesis.
Not sure, /etc sounds like a pretty weird choice for storing the logins.
Juuuust to be sure: You have installed skype in your template right?
And you created a normal AppVM based on that template?
And you use the AppVM instead of the template?
If so:
Then you have to figure out where skype stores stuff.
A quick search hinted to this file that has rotten away unfortunatelly, but in the cache i read:
In Linux , Skype stores the ‘config.xml’ file in $(HOMEDIR)/.Skype/< skype user id>
So this should work out of the box how i described it above.
Most likely not stored in plaintext but as session id.
Can also check /opt
