I would like to install PuTTY in Qubes.
In Template, I type
sudo add-apt-repository universe
sudo apt-get update
sudo apt-get install PuTTY
It does not add repository and does not install PuTTY.
If you can install PuTTY yourself and let me know it can be done and commands used, please post. Or at least post mistake i make.
