i installed fuse on fedora-40 ;
Installed: fuse-2.9.9-21.fc40.x86_64
Next i shall re-try Freetube app image, thanks
Thanks
I have just updated dom0 and realized that everything i did before has been wiped so im re-doing and copy your prior post which worked for Brave on Fedora40 but im wondering if you perhaps know how to do the debian template brave repo as i tried using the fedora commands just changing dnf with apt but it no work for me? thanks
i did try it as found the app image still in my folder from pre-update of dom0 yet it no play any video for some reason though!
and is very awkward for me to use, would you know how i can getting the freetube repo for templates please?
There is no repository for freetube. There are deb/rpm packages available for download:
You can download the package, move it to the template and install it there, e.g. for debian:
sudo apt install /path/to/freetube_0.21.3_amd64.deb
But it wonāt be updated automatically and youāll need to download and install new versions manually.
You can install the freetube in the template using flatpak, then itāll be updated automatically:
