How to increase HVM window size
Good evening all,
I would like to increase the window size of my HVM as it is just a little bit too small to my liking. Click and drag window size doesn’t work and right click on the title bar I see the option for full screen but that doesn’t work either.
So how might I increase the window size for my HVM?
Thank you for your time
Did you try to change the resolution inside the HVM?
No that didn’t even occur to me, My thinking is I thought qubes would be in control of the HVM window size not my OS internally
@fsflover thanks man, that did the job my friend
