I have a browser based app (on Chromium) that I need to run on a Fedora VM qube.
It is very resource intensive and no matter what I do the VM gets completely bogged down.
The VM itself will constantly be at 90%+ CPU usage, fan runs non-stop, while the system wide utilization is only 5-10%.
Things I have tried:
-Give it more RAM. Allocated up to 40GB on a 48GB system. Helped a little but CPU seems to be the constraint
-Give it more vCPUs - did not seem to have any effect
-Shut down all other qubes - Gets more ram, but still CPU limited.
This is a skylake i7 with 48GB Ram and NMVE M2 SSD OS drive, it should be able to run this app very easily.
Should I convert it to a different type of Virtualization?
Thanks!
