The adapter is recognized by sys-usb and can be attached to any qube, seems fine.
However the problem I have is that the adapter is not functioning as intended–its not connecting to wifi. In the sys-net device tab, Qubes automatically selected my laptop’s ethernet and network controller as the connecting devices. Those sys-net network controllers are seemingly used as internet connectors for all the qubes.
I tried installing the needed 8814au driver for the adapter in the sys-net terminal, but still have the same problem as a result. Though perhaps I installed the driver in the wrong terminal or incorrectly (I followed the Debian command line instructions from the Realtek website)?
I would greatly appreciate any help or insight. Thank you.
(I am running Qubes 4.1 (Debian 11) on a Lenovo Thinkpad T51)
I’ve reinstalled the required driver and the needed packages. Everything should be operational but when I connect the adapter to sys-net, the connection is through the laptop PCI network controllers and not the adapter.
I can’t identify any errors on the wifi adapter’s part. The adapter works fine with my other Laptops/PCs (windows and kali linux), but with qubes I can’t seem to figure it out.
I thought maybe if I disable the PCI network device in the sys-net it would default to the adapter, but last time I messed around with the PCI device connectivity I ended up having to completely re-install qubes on my laptop. After disconnecting some device from a qube, I tried to start/resume it and the whole OS just frozen. I power button restarted my laptop and after that every time I unencrypted the drive (and the default VMs would auto start) the system just froze. So then I disabled auto start and was able to get in to the home screen, but every time I tried to start/resume a qube the system would just freeze until I just powered the laptop down. Pretty much I am on a re-installed qubes OS and am still trying to figure out how to connect this adapter.
Analyze or post here the journalctl log from sys-net when you connect the USB WiFi adapter to sys-net.
There should be relevant messages as to why it’s not working.
