The title pretty much says it. How can I get qubes-manager to automatically open up after I log in to Qubes? Please post the steps if you can.
From dom0 System Settings, open “Session and startup”.
Then in “Application Autostart” tab add a new entry.
Give any name and then in “Command” filed give this command
qubes-qube-manager
Check if the trigger is “on login”.
then save it.
From now on qubes-manager will automatically open up after logging in to Qubes
Is there a way to start in on a special Desktop ? Would like to have it on “4”
Thanks a lot!
