Hey!
So I have been trying to get OrcaSlicer working in QubesOS for a little bit with no luck. The software launches but any dropdown would disappear. This isn’t sepeific to QubeOS but a few window managers also have this problem.
This fix requires you to compile the software yourself. It isn’t too complicated and will leave you with a Flatpak. The only thing I haven’t got working is the video stream for my printer (Bambu p1s). I think this is because it requires a proprietary video codac which I haven’t spent time debugging. Never the less, you will now be able to use OrcaSlicer in QubesOS.
This guide will assume you are using Fedora as I haven’t testing this on Debian. It shouldn’t be to hard to build on Debian but you might need to figure out package names.
One thing to note, this is currently fixed in Bambu Studio (which I refuse to use after all the stuff they did), so it should be coming to OrcaSlicer some time soon so it might be worth checking.
When you do have OrcaSlicer installed, if you are using a BambuLabs printer you will have to manually add the printer, when you enter the IP + PIN it will fail and you will have to also enter some other details (there should be a button that appears called something like “Manual Setup”). You will then add the model number, serial and select the model from a dropdown list.
Clone the code
I am using the main branch. OrcaSlicer - Github
Modify two parts of the code
You need to modify these two files:
src/slic3r/GUI/Widgets/PopupWindow.cpp
src/slic3r/GUI/Widgets/PopupWindow.hpp
In each, find and replace topWindowActiavate with topWindowActivate
For vim, you can use :%s/topWindowActiavate/topWindowActivate/g
Install Build Deps
dnf install flatpak-builder fuse
You can do this in your template or in your live VM but, if you do it in the live VM, the packages won’t persist.
Build the RPM
Now you want to navigate to where you cloned the git repo too. You then will want to run:
./build_flatpak.sh -i
This will require 10GB-ish of ram but if you pass the option -j 1 it will limit how many cores it uses. When I was building it without that it would crash the VM. Personally, I set mine to -j 4 and it worked fine but you might have to play around with it.
Done
Now you should have a Flatpak file, you can go ahead and install it. If you don’t have the flatpak stuff setup, you should referance this guide: dataswamp.org’s Artical
Conclusion
I think I should have covered all the steps required to get this working. If you have a problem, please reply and I will try to get back to you.
Sources:
UPDATE: For some reason, the video stream started working. Not sure why.
