How to get display settings to persist?
I have a double monitor setup and every time the laptop reboots or the second monitor is reconnected, I have to reopen the dom0 display settings, enable disable mirror displays, and readjust their positioning. How can I make my adjustments persist?
Never mind, playing around in the Advanced section I figured it out. I had to toggle “configure new displays when connected,” “Automatically enable profiles when new display is connected” and create a profile in the top section. Thank you anyway! :slight_smile:
