Goes evening all,
I am building out a FreeBSD HVM and I am having a very difficult time with the graphics. So I am wondering is there a way to find out what graphics driver Qubes is is using?
So that I can install same drive in FreeBSD.
Thank you
Goes evening all,
Thank you
install driver is not simple if it not in kernel
Presumably FreeBSD is running as an HVM. This means a small Linux-based VM called a stub domain is also started that provides QEMU services to give the HVM virtual hardware to use, including a virtual video card. I believe two options are made available in Qubes.
I recommend searching the qubes docs for “cirrus” to look at how to change the video adapter.
E.g. qvm-features – manage domain’s features — Qubes Admin client v4.1.19-0-ge9419c3-dirty documentation
Thank you, I believe my problem is that I have to find the right gxp driver for FreeBSD/Xorg combo, then edit boot,xinit,rc.conf to get this working. Thats my problem I am finding out. Xorg can be a chore to setup from base to work with a gxp driver and the big problem is finding thee right driver!!!.
Inorder to get FreeBSD working right as a HVM…
pkg install -y xen-kernel xen-tools
Then do configurations as needed…
