I have a need to export a VM from qubes to a virtual machine, like VMware or VirtualBox.
I’ve found instructions to go from VMware to Qubes, but I need to go the other direction.
I’ve found qubes-backup, but it encrypts the file (you cannot do a backup without a password) and I don’t understand the file format. Ideally, I’d like a plain ‘dd’ hard drive image of the VM, with no encryption. (.img, .hd, .cow, whatever)
Ideally, I’d like to export my custom Template. My second choice is to export a pvm. Worst case, I’d be okay with exporting a HVM (if I can build the HVM from my template).
Any ideas?
