How to exclude a specific qube from updates
Hello,
I am wondering how to exclude a template from automatic updates. Because of its specific usage, it will never be updated the normal way. And I do not want to have the update widget permanently displayed, making me think that an update is pending…
Thank you!
EDIT: I can see a “qubes-update-check service” in the list available in the AppVMs services tab, but it does not seem to be enabled (I understood that the AppVMs do the update check for their parents).
It looks like I managed to fail a simple search :sweat_smile:
qvm-features is what I was looking for (as you see I am discovering the OS).
Thanks!
