In dom0 I set the “enabled” value to ‘1’ in /etc/yum.repos.d/qubes-templates.repo for both
qubes-templates-itl-testing and templates-community-testing. I updated dom0.
When I run qvm-template-gui I do not see any additional templates listed from these repo. What am I doing wrong?
I am running 4.1 rc2 updated (which should be upgraded to rc3 that way), Are correspondent metalinks uncommented in qubes-templates.repo? Other then that, I have an idea. Here’s the content of my qubes-templates.repo:
The contents of my qubes-templates.repo is exactly the same as yours.
On a side note, I noticed when I installed rc2 the templates from the testing/community repo showed fine in qvm-template-gui. Now on a fresh install of rc3 they do not show.
I also have the same issue with a fresh install rc3
Even manually enabling the testing repository in qubes-templates.repo does not change any results.
Thankfully I have a backup of my fedora-35-minimal that worked in rc2 I was able to import.
I am not sure what else to try.
Maybe to rename topic’s subject to something more attracting to developers - Enabling community and testing template repos in Qubes-OS v4.1 rc3 doesn’t work, for example…?
