For some Dell laptop (such as mine), There is a Display port direct output mode option in Video → Switchable Graphics, enable it and it will assign all display port (mDP, HDMI, Thunder Bolt etc.) directly to the dGPU. Check if your BIOS offer some similar options.
If there is no way to use Intel GPU for your laptop display and Nvidia GPU for HDMI then you can try this:
I shouldn’t even suppose to get Nvidia working with external display if the display connected through Intel-Nvidia HDMI?
I most definitely have the MUXless laptop.
Just for the sake of it, tried to install manjaro without Qubes and it picked the right drivers, but when I tried it with Qubes, no matter what I did, it just didn’t work.
Maybe I did miss something.
Prob gonna give up on GPU passthrough, it ate 3 days out of me already.
I think so. At least not directly.
If you have your external display working in dom0 with iGPU then you can just passthrough Nvidia GPU to some qube and use VirtualGL inside this qube. Then you can move this qube window to your external display in dom0 and make it fullscreen.
You didn’t passthrough your Nvidia in manjaro. It’d work the same in dom0.
You can try to passthrough your GPU in KVM in manjaro and try to use HDMI - then it’d be comparable.
