How to downgrade to the 4.19 kernel?
@ludovic recommended to try the 4.9 kernel to address the issues I am seeing. I have tried to follow the documentation.
sudo qubes-dom0-update kernel-4.9.56-21.pvops.qubes.x86_64
…returns with “no match” / “nothing to download”
However, I see that package version on yum.qubes-os.org
sudo qubes-dom0-update --action=install kernel-1000:4.9.56-21.pvops.qubes.x86_64
…does nothing either.
I downloaded and installed manually. But I’d love to learn “the right way” please.
Also: now my dom0 runs 4.9.56-21 while my debian qubes run 5.4.98-1 … will this be an issue?
I will download and install kernel-qubes-vm-4.9.56-21.pvops.qubes.x86_64.rpm to be sure.
But once again: please help me understand
Sorry @Sven, it isn’t 4.9 but 4.19.
So the right way, read the explanations from @icequbes1 , you’ll find that the last 4.19 kernel is 4.19.182 for the current repository.
So try something like:
sudo qubes-dom0-update --action=install kernel-1000:4.19.182-1.pvops.qubes
Will do. Thanks!
I must be doing something wrong:
OK, I think I got it… kernel-419-4.19.182-1.pvops.qubes.x86_64
I tested, it’s:
user@dom0 ~]$ sudo qubes-dom0-update --action=install kernel-419
command output
Using sys-firewall as UpdateVM to download updates for Dom0; this may take some time...
--> Running transaction check
---> Package kernel-419.x86_64 1000:4.19.182-1.pvops.qubes will be installed
--> Finished Dependency Resolution
kernel-419-4.19.182-1.pvops.qubes.x86_64.rpm                |  50 MB  00:04
Successfully verified /var/lib/qubes/dom0-updates/packages/kernel-419-4.19.182-1.pvops.qubes.x86_64.rpm
Qubes OS Repository for Dom0                    125 MB/s | 161 kB     00:00
Dependencies resolved.
 Package      Arch     Version                        Repository           Size
Installing:
 kernel-419   x86_64   1000:4.19.182-1.pvops.qubes    qubes-dom0-cached    50 M
Transaction Summary
Install  1 Package
Total size: 50 M
Installed size: 252 M
Is this ok [y/N]:
Explanations : the repomd.xml refers the repodata/0d0fc2a6e28dbf0fd656c000f93d56316f41371182301ec0587d3c781ac3433f-primary.xml.gz which contains:
<package type="rpm">
  <name>kernel-419</name>
  <arch>x86_64</arch>
  <version epoch="1000" ver="4.19.182" rel="1.pvops.qubes"/>
So the package name is kernel-419.
I just saw your last comment, ok it works also with adding .x86_64.
Thank you @ludvic! … about the qubes - should I also downgrade kernel-qubes-vm? I guess so.
No only the dom0 kernel.
@ludovic provided the right answer, but my initial thoughts from the first post were if you were sure you wanted kernel 4.9? That is quite old and is considered a 3 year old stale branch according to Github 0.
If an older kernel version branch is sought (older than 5.4), kernel version 4.19 is available and is an active branch; it is available as package kernel-419 (and kernel-419-qubes-vm).
In terms of downgrading instruction, what you tried, as well as what is documented, is the right way.
It appears the Qubes 4.0 current repo metadata only includes the latest packages, or some packages after a certain point. A quick and weak bisect shows that somewhere between November and December 2020 only the latest packages were included in the repo metadata. Perhaps this was a repo “refresh” to minimize the size of repodata? I am not sure and have not investigated any package generation changes that occurred around that time.
What this means is if you perform manual .rpm file downloads, it will be up to you to resolve any dependencies since you are no longer relying on repo data to find and install dependencies for you.
And as always, be cautious of what rpms you install, especially in dom0. Older packages that are properly signed may have vulnerabilities that were later fixed in future versions.
