A Lenovo Thinkpad W540 will not boot off a Qubes_OS 4.2.3 Installation disk. It starts to boot and then reboots. (Please see Qubes-dist-upgrade (4.1 to 4.2) Details for other related questions)
I want to diagnose why the installation disk boot fails to boot and would appreciate any relevant advice.
After the boot failure I tried the “Troubleshooting - verbose boot and installation Qubes-OS R4.2.3” menu option and this is an abbreviated annotated version of the video recording I made of the output:
[ 15.2225581] audit: type=1130 ... msg='... res=success'
[OK] Finished systemd-vconcsole-...rvice - Setup Virtual Console.
[OK] Finished systemd-tmpfiles-...te Volatile Files and Directories
<garbage text>
Started dracut-cmdline-as...r additional cmdline parameters...
[OK] Finished dracut-cmdline-as...for additional cmdline parameters.
<garbage text>
[ 19.278031] audit: type=1130 ... msg='... res=success'
Starting systemd-udevd.ser...ger for Device Events and Files
[OK] Started systemd-udevd.serv...nager for Device Events and Files
<garbage text>
[ 22.1557441] audit: type 1334 .... <multiple lines of this>
<pages of garbage text>
Blank Screen for a while
Kernel panic screen
Please note the garbage text references, Blank Screen and the fact it ends with a kernel panic.
The garbage text predominantly has accented characters and those characters mostly are based on G,L,I,k,g,N,n,r,H,h,…
Is this garbage text normal? I note that this garbage text seems to come shortly after “audit”.
Is it possible to:
- pause and resume the boot process?
- save a log file?
I did not use any command line switches in GRUB. Is there anything that I should try?
