Like the title says, a lot of my software shows up as white squares in the system tray because it’s third party software. How can I modify the white scheme to use a custom icon?
It is not easy as many of those icons are dynamically generated and are not fixed png or svg files. Examples of dynamic icons are Wireless signal strength icon and Whonix’s Tor status widget.
But you can change the default filter Qubes applies on those icons. It is in Settings => Qubes Tools => Qubes Global Config => General Settings => Tray icon style.
login/logoff might be necessary after changes.
p.s.:
Also please see this post:
