How to copy Win-11 to a template AFTER installing and Qubes-tools and moving Users to private drive
Trying to convert a Win-11 HVM to a Template using qvm-create --class TemplateVM ,–root-move-from command as stated in docs. Problem is it is missing the separate Users on the second Q: drive seemingly since it doesn;t move the private.img. I manually moved the file and it boots however I loose the ethernet adapter. Have tried to find a driver to simply install with no luck. Seams the Wn10 uses a RTL8139 driver but Win11 wont accept the driver. Neither will a straight Win11 install in a HVM. A Win11 install using the qvm-create-windows-qube process works but installs Qubes-Windows-tools by default so puts me in same situation. Any help is appreciated.
