How to copy bit-by-bit one Qubes USB-stick in one usb-contact to another USB-stick in another usb-contact using Qubes or Mint?
How to copy bit-by-bit one Qubes USB-stick in one usb-contact to another empty USB-stick in another usb-contact using Qubes or Mint or other Linux solution when one feels that the present bootble usb-qube os is optimal for the moment and needs to have this solution backed-up so this backup usb also is bootable and not in need of long configuration. Have any experience of a functional solution?
You can use the command dd to copy all bits from the source USB device and store it as a file (you may want to compress it and/or encrypt it (after compression) or at least store a checksum of the file).
Then, you could burn a new USB device using dd again using the dump file as the source.
It may be good to use 95% of the disk on the original USB disk when creating the partitions, otherwise if the destination USB devices are slightly smaller this won’t fit and could create problems.
Tank you so much solene for dealing your advise to me. This solves my ever present behavior to make functional backups for worst case scenarios. And by this way I presume that I later also can store this with dd made “in the middle” file on a M-disk (upp to 100 GB storage space, secure >100 years) for later loading on a new bootable USB-stick then getting again a personal functional Qube system. Unfortunately USB-sticks can by time stop functioning. But I realize that this procedure must be continuously repeated as the nr one Qube USB-stick that is in use must be updated and upgraded regarding several time limited ongoing processes over time.
