I am using the sys-multimedia setup in which the multimedia qube uses a minimal template, and only the disposable has the programs needed to open videos/images, etc.
I can run xdg-open or qvm-open-in-dvm in the multimedia qube, but it is extremely time consuming doing this for each single file.
I know that in Qubes’ Thunar integration adds a “Move directory to other qube” menu; is there a CLI command that does the same?
