I am attempting to create a Qube from a Linux distro which only comes as a USB install .img. By the instructions I see, I need to
distro to be an .iso.
Therefore I need to convert the .img to .iso.
Any suggestions.
Any suggestions.
Many problems that people have in Qubes are actually not Qubes specific.
This is one of them.
You can use genisoimage to convert the disk image to ISO format. Or
mount the .img file and create an iso from the mount point using mkisofs.
You can also try ccd2iso or iat - I’ve used both in the past, with varying
degrees of success. If one doesnt work, you may be lucky with the other.
Hi there.
I think it’s not a good suggestion for all cases.
i.e.: chromeOS derived distro are .img, but inside there’s on a full GPT layout with several partitions for firmware, kernels, system data and the writable stateful area. That structure cannot be preserved inside an ISO without breaking boot compatibility across devices.
So conversion to .iso is impossible in these cases (I learned it in the hard way!
rif.: Installing FydeOS on Your PC: A Step-by-Step Guide | FydeOS Help Center
<<Why not .iso?>> paragraph…
So, I’d convert a .ova to virtualbox, then try to import in qubes…
It’s really a lot of work for a simple test…
cheers!
M.
