I have a problem with qubes os wifi it will not show the wifi networks. I have tried searching in the forums but no luck. My wifi card is not being recognized by qubes. In my pc i just unplugged it and then it is recognized i dont know the logic behind it dont ask me. Any way i can get qubes to recognize my wifi card.
Thanks.
What is your WiFi card model? Is it PCI or USB?
It is not an external device like an adapter, it is an intel card.
Get its model and search for it on this forum, maybe you’ll find a way to fix it.
Maybe you’ll need to use kernel-latest or newer firmware for it to work.
Thanks
