I started running KDE Connect in HVMs (WIN11 and DEBIAN11) on QubesOS R4.1 - and it is awesome because I can transfer files very easily between all my devices (iphone, pixel, mac, and those HVMs). I do not get my firewall settings running in a way to connect KDE Connect properly through my firewallVM and netVM - I need port forwarding from netvm to HVM on ports 1714:1764 udp/tcp - and that is a lot of tweaking. So I attached a WIFI usb to my HVMs and opened up a hotspot (very simple). Then I connect the device I want to share files with to this hotspot - works like a charm! I could even copy those files from my WIN11 HVM to other appVMs ![]()
Now I want to integrate it to make it available for general use in QubesOS - to my concern it would be ok to run KDE Connect even in my netVM (it is disposable). I would open KDE Connect transfere files to or from a given device in my home network to or from netVM and would be able to move those to or from a desired appVM.
Has anyone been able to set this up a appVM in qubesOS? If so would you please share how you set it up?
Best regards
