Qubes installer is killing my eyes on a 4K display. I need to use a magnifying to see the microscopic fonts.
How can I change the resolution?
Good question. I feel the same discomfort with the default resolution.
There is $DISPLAY env variable for Anaconda but dunno what can be typed there. Check grub menu for install if it’s present.
Or in grub menu add inst.resolution=1920x1080
Could you please tell where exactly to type that? (on the vmlinuz line or somewhere else)
Edit grub menu entry that is for installation. Search for inst.stage2= and add at the beginning
QT_SCALE_FACTOR=2
and at the end
inst.resolution=1920x1080 video=1920x1080
It’s wild bet.
There is no such thing on any line. I tried the suggested inst.resolution but it did notihng. video affects only console.
It was from fedora net install so it was wild bet.
