How to boot Chrome OS?
Chrome OS Flex is a bin file so I think I probably need to convert
I think if I write to the actual flash drive with BalenaEtcher it will be successful, but I have to create a loopback device and write to it with the dd command, right?
Can I solve it by running the qemu-img convert?
This might help:
What does file <name-of-chromeOS-file>.bin give you on the command line?
Although it has a .bin as extension for it’s filename could it be safely assumed to be an ISO?
Hi there.
IMHO it isn’t…
Boot Failed: Could not read from CDROM (code 0005)
cheers.
M.
