How to: automatic change of templates
I am a QubesOS heavy user. I separate almost everything. Because of it I have a ton of VMs I have to switch to Fedora 34. Is there a way to run it in one single command from dom0?
Note: I have ~20 VMs called storage-XX.
My idea was: qvm-prefs storage* template fedora-34
Unfortunately, this does not work. Also, I would have to match a number of groups. Much more advanced would be a command that simply matches each VM on fedora-33 and switches to fedora-34.
I am familiar with the in-place upgrade method. However, I’m looking more for a quick and dirty method without much risk of screwing something up:
  1. downloading the new template
  2. single line toggle command
Can someone please help me out?
You also can do this in the GUI, means open Qubes Manager > System > Manage Templates for Qubes. Then select all qubes, which have to be changed and down on the list change the drop down list to the desired template… click ok
This is a simple exercise in bash:
for v in `qvm-ls --raw-list | grep ^storage`
do
        qvm-prefs $v template fedora-34
done
Something like this…
qvm-ls --raw-data --halted --fields NAME,TEMPLATE | awk -F "|" '$2 ~ /fedora-33/ { print $1 }' | xargs -I{} qvm-prefs {} template fedora-34
It would be better to shutdown all qubes using qvm-shutdown --wait --all before doing that.
Thanks for your help.
However, I suspect that your solution may not be as follows: Move all fedora-33 VMs to fedora-34
It is still GUI click of death.
