This might sound like an issue outside of qubes but i think it is a qubes issue. I cant change the brightness in my linux qube specifically kali linux. I have tried changing the brightness with xrandr and it didn’t work also with xbacklight. I think the problem is the virtual screen maybe it doesnt work with vm. Ultimately if it isnt possible to change from the qube could there be a solution from dom? Any help is appreciated.
Here are two commands i tried :
xrandr --output [displayID] --brightness [X.XX]
xbacklight -set 50
Nothing changed
You have to run the commands in the qube which controls the display, usually dom0 (alternatively sys-gui).
How do i do that?
You open a dom0 terminal! Easiest way to achieve this is to right-click on the Desktop and, from the menu that pops-up, select Open Terminal Here.
Kinda of solved Thanks
ddcutil only - it sends command to monitor not to change gamma/contrast of the signal
first, install
sudo qubes-dom0-update install ddcutil
then detect monitors
ddcutil detect
that’s what is my report
Display 1
I2C bus: /dev/i2c-2
DRM connector: card0-HDMI-A-1
EDID synopsis:
Mfg id: AOC - UNK
Model: AG275QXN
Product code: 42244 (0xa504)
Serial number: VOKP1JA000899
Binary serial number: 899 (0x00000383)
Manufacture year: 2023, Week: 5
VCP version: 2.2
Invalid display
I2C bus: /dev/i2c-10
DRM connector: card0-eDP-1
EDID synopsis:
Mfg id: AUO - UNK
Model:
Product code: 64155 (0xfa9b)
Serial number:
Binary serial number: 0 (0x00000000)
Manufacture year: 2021, Week: 0
DDC communication failed
This is an eDP laptop display. Laptop displays do not support DDC/CI.
as you can see I have one external monitor and one internal laptop - only external have DDC/CI capabilities
it’s best to address monitors by I2C bus because it’s constant - monitor number might change during boot
for my monitor, it’s I2C bus: /dev/i2c-2 - you interested in the number only → 2
now check for monitor capabilities, for my monitor it will be -b 2 option as it’s number 2 on I2C bus
ddcutil capabilities -b 2
result
Model: AG275QXN/EU
MCCS version: 2.2
Commands:
Op Code: 01 (VCP Request)
Op Code: 02 (VCP Response)
Op Code: 03 (VCP Set)
Op Code: 07 (Timing Request)
Op Code: 0C (Save Settings)
Op Code: E3 (Capabilities Reply)
Op Code: F3 (Capabilities Request)
VCP Features:
Feature: 02 (New control value)
Feature: 04 (Restore factory defaults)
Feature: 05 (Restore factory brightness/contrast defaults)
Feature: 08 (Restore color defaults)
Feature: 0C (Color temperature request)
Feature: 10 (Brightness)
Feature: 12 (Contrast)
Feature: 14 (Select color preset)
Values:
01: sRGB
05: 6500 K
06: 7500 K
08: 9300 K
0b: User 1
Feature: 16 (Video gain: Red)
Feature: 18 (Video gain: Green)
Feature: 1A (Video gain: Blue)
Feature: 52 (Active control)
Feature: 60 (Input Source)
Values:
0f: DisplayPort-1
10: DisplayPort-2
11: HDMI-1
12: HDMI-2
Feature: 62 (Audio speaker volume)
Feature: 86 (Display Scaling)
Values:
01: No scaling
02: Max image, no aspect ration distortion
05: Max vertical image with aspect ratio distortion
0b: Unrecognized value
0c: Unrecognized value
0d: Unrecognized value
0e: Unrecognized value
0f: Unrecognized value
10: Unrecognized value
11: Unrecognized value
12: Unrecognized value
13: Unrecognized value
Feature: 8D (Audio mute/Screen blank)
Feature: AC (Horizontal frequency)
Feature: AE (Vertical frequency)
Feature: B2 (Flat panel sub-pixel layout)
Feature: B6 (Display technology type)
Feature: C6 (Application enable key)
Feature: C8 (Display controller type)
Feature: CA (OSD/Button Control)
Feature: CC (OSD Language)
Values:
01: Chinese (traditional, Hantai)
02: English
03: French
04: German
05: Italian
06: Japanese
07: Korean
09: Russian
0a: Spanish
0b: Swedish
0c: Turkish
0d: Chinese (simplified / Kantai)
0e: Portuguese (Brazil)
12: Czech
14: Dutch
16: Finnish
1e: Polish
Feature: D6 (Power mode)
Values:
01: DPM: On, DPMS: Off
04: DPM: Off, DPMS: Off
05: Write only value to turn off display
Feature: DC (Display Mode)
Values:
00: Standard/Default mode
Feature: DF (VCP Version)
Feature: ED (Manufacturer specific feature)
Feature: FF (Manufacturer specific feature)
there is capability, named Feature: 10 (Brightness) in VCP Features: and ddcutil can set vcp features
so, for my monitor, setting brightness to 100% will be ddcutil for monitor -b 2 set feature brightness setvcp 10 to 100
ddcutil -b 2 setvcp 10 100
i’ve made alias in ~/.bashrc.d/aoc_brightness
alias aocbr="ddcutil -b 2 setvcp 10 $1"
and now I can change brightness of my monitor to 20% (don’t need more than 40% because my eyes are bleeding) by issue in dom0 terminal:
aocbr 20
