/etc/X11/xorg.conf.d/20-intel.conf
Section “Device”
Identifier “IntelGraphics”
Driver “intel”
Option “AccelMethod” “sna”
Option “TearFree” “true”
EndSection
end of 20-intel.conf
Above config file needs to be added, kindly share how to add and create this file. never used linux based system before.
Open a terminal window: click on the Q app menu (top-left) and select Terminal Emulator.
Then run the following command:
[user@dom0 ~]$ cat << EOF | sudo tee -a /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
Identifier "IntelGraphics"
Driver "intel"
Option "AccelMethod" "sna"
Option "TearFree" "true"
EndSection
EOF
You can confirm a successful execution with:
[user@dom0 ~]$ cat /etc/X11/xorg.conf.d/20-intel.conf
Mind that the config you posted uses ” which will likely result in errors. The code I suggested uses " instead.
