Systrays are like the blue cube and the USB stick icons and like the two of sys-net and sys-whonix, those appear at the right
of the panel. What command to run in dom0 so I can add my own?
You shouldn’t need to do anything, if the/your application has a systray icon, it will automagically appear. For example, VeraCrypt, zim, NetworkMananger (if you have a sys-vpn type construct)…
Additionally, systray icons of applications will by default be tinted in the colour of the qube they’re running in. So say you’re running one copy of zim in an AppVM marked red, and one in AppVM marked yellow, you’ll have one red and one yellow tray icon for zim.
