How to add a deb repo to a template?
I am following librewolf installation steps here:
However, during the template setup (just for using librewolf browser) how am I supposed to use wget to get their gpg key, since the templates have no internet connectivity. When I try wget, it fails saying “temporary domain resolution error.”
How to add their repo to the debian template’s apt repos?
Use the localhost:8082 http proxy
Can you spell out the commands for that?
A fully-offline-TemplateVM alternative to using a http proxy would be to wget the key in an AppVM and then copy it to a template. Then proceed with the instructions.
curl --proxy localhost:8082 https://deb.librewolf.net/keyring.gpg
Yes, I thought of that, but I am actually writing a script to automate the librewolf template creation. Thus I would like to stay away from manually copy-pasting the key.
can I do the proxy with wget ?
Yes, but I don’t know the parameter you need to set the proxy address, but it’s just a standard http proxy running on localhost port 8082 it works with all applications.
I am routing all the installations and updates through sys-whonix. Localhost:8082 port is failing. What is the correct port number in this case?
I am unable to parse the relevant information there.
I don’t use Whoinx, but this seems to be what you need to do.
The updates proxy uses RPC/qrexec. The proxy is configured in qrexec policy in dom0: /etc/qubes-rpc/policy/qubes.UpdatesProxy
# any VM with tag `whonix-updatevm` should use `sys-whonix`; this tag is added to `whonix-gw` and `whonix-ws` during installation and is preserved during template clone
@tag:whonix-updatevm @default allow,target=sys-whonix
@tag:whonix-updatevm @anyvm deny
This might get you some answers
Thanks but it is way too long a thread. I am using the appvm to download the .gpg file and using the qvm-move-to-vm tool to get that file back into the template.
@tanky0u
