Can anyone give me a working guide for plugging in and successfully attaching a USB stick to a qube where you can access its data? Because If I plug in a usb stick it does show in the main toolbar, but when I attach it to a qube it doesn’t work or show itself in the qube.
if you wanted to open the USB as a “data block” from say the Qube,
Named Work. Go to the Qube work, on the Click on Work.
On the dropdown menu in the second column to the right.
Click Thunar File Manager.
when the USB is inserted. look upper right at icon of USB stick next to red internet connection.
click on USB icon, just to the left a dropdown menu… one of the entries , the top one with USB, hover pointer. on the USB.
another drop down menu appears. showing the Qubes one can connect the USB to…
If a Qube does not have fie manager. One can install it thru.
Settings in the target Qube.
fifth tab over, Applications. Install File manger. To get it to appear as a tab on that Qube, click “refresh applications”
one version of Thunar File Manager was alreaad y in Work. Unless I installed it and forgot I did.
Thanks for the input, but I’ve tried this and it doesn’t work. I think usually there is a ‘USB incoming’ tab that comes up if the USB successfully attaches to a qube. This happens regardless of what qube I try to attach it to.
It has come up with an error message before as well: ‘Qubes daemon access error. got empty response from qubessd.’
