tree
June 16, 2023, 1:25pm
1
I have to store things (passwords) in the Gnome Keyring. (I access access Google Drive in Nautilus via Gnome’s Online Accounts facility).
I need to update the password for that keyring. The Gnome instructions seem to refer to a GUI menu for this, which I can’t see.
How do I access these menu options on Qubes?
edit: $ gnome-keyring isn’t helpful.
not really Qubes specific.
from the manpage of gome-keyring:
https://man.archlinux.org/man/extra/gnome-keyring/gnome-keyring.1.en
You have the section:
SEE ALSO
secret-tool(1) , seahorse(1) , gnome-keyring-daemon(1)
from the manpage of gnome-keyring-daemon:
The gnome-keyring-daemon implements the DBus Secret Service API, and you can use tools like seahorse or secret-tool to interact with it.
secret-tool is the command line tool.
seahorse is the graphical interface.
The answer is also there:
https://wiki.archlinux.org/title/GNOME/Keyring
First result of the search:
https://www.startpage.com/do/search?q=gnome+keyring
tree
June 17, 2023, 10:36pm
3
Thanks, but EDIT seahorse manages the keys within the keyring, not the keyring itself. Its not the menu I was looking for.
I haven’t run secret tool, but from the archlinux page description, it doesn’t look like it will access the keyring’s password.
I’m looking for the GUI menu the Gnome docs refer to.
Thanks for your help, though.
tree
June 17, 2023, 10:46pm
4
I was wrong.
For posterity:
In seahorse, right click ‘Default keyring’ and find a menu option to change password.
@tree I marked @szz9pza ’s reply as the solution to make it easier for so folks with the same question as yours to find it. You can do that from the little menu that opens when you click the three dots (…) button near any post. Of course, please correct if needed as you see fit!
