The only qube which shows a line service.qubes-update-check
is dom0 and there is no 1
on it.
supported-service.qubes-update-check
with a 1
is shown for:
debian-11
fedora-36
whonix-gw-16
whonix-ws-16
What does this mean?
on it.
with a 1
is shown for:
debian-11
fedora-36
whonix-gw-16
whonix-ws-16
It means that you have not disabled the qubes-update-check service at
all.
Hm. I may have misunderstood the interface. In “Updater checks” section the checkboxes are unchecked. I assumed (obviously wrongly) that the “Disable All” button is equivalent to that but now I understand that clicking the button does something else. After clicking it I see service.qubes-update.check
without 1
for all qubes.
Does that confirm that now I have disabled the qubes-update-check service for everything?
If you look carefully, you will see that the checkbox refers to “new
qubes”, and the button to “individual qubes”. If that said “existing
qubes” it would be clearer.
Yes
Thank you!
Could you please clarify the reason for the significant difference between the sum of the forecast and the actual traffic used?
I’ve always found the Debian prediction to be pretty accurate.
If you have the original bare templates, try dealing with them
individually to see if you can pin the difference to a particular
template.
If you don’t, in future select the templates one by one in the update tool
Thank you!
