Ver: Qubes R4.1.1
I have a fairly good machine with 16 GB of RAM. However, Qubes IDLES at 13.6 GB! Here’s the breakdown of what percent of memory goes to each domain, as per xentools (all values rounded to 4 sig figs):
1 running domains, 6 blocked, 0 paused, 0 crashed, 0 dying, 0 shutdown
Dom0 = Mem: 4.177 GB (25.2%), Max Mem: 4.195 GB (25.3%)
Sys-Firewall = Mem: 4.079 GB (24.6%), Max Mem: 4.097 GB (24.7%)
Sys-net = Mem: 393.0 MB (2.4%), Max mem: 411.0 MB (2.5%)
Sys-net-dm = Mem: 148.0 MB (0.9%), Max mem: 149.0 MB (0.9%)
Sys-USB = Mem: 291.0 MB (1.8%), Max mem: 308.0 MB (1.9%)
Sys-USB-dm = Mem: 148.0 MB (0.9%), Max mem: 149.0 MB (0.9%)
Sys-whonix = Mem: 4.080 GB (24.6%), Max mem: 4.097 GB (24.7%)
The above figures are from after I started up the machine. Please note that a USB wifi receiver was assigned to sys-net during the time of these figures. Also note that the only other thing running on Qubes was xentools.
This is obscene. Why would these domains using so much memory? I don’t see any error messages that could indicate failures.
Since I want to run more than just the default domains, how do I minimize RAM use of sys-firewall and sys-whonix? Should I try cutting down the amount of RAM allocated to these?
Please note that I do want to use sys-whonix and sys-firewall, but I feel like this is just a bit excessive.
