I have an IcyDock that can handle four extra, hot-swapable SATA SSD drives. I unplugged them to install Qubes, then plugged them back in after all was running.
They are not seen in any file manager, except the one found at ‘start’>'settings>Other>Thunar File Manager (It is labeled as dom0), and the listing that pops up under Qubes Devices in the taskbar.
No matter what I do, I cannot seem to mount them under any other VM. Therefore, I cannot even open my password safe in Vault since the database is on one of those drives…
Where is the GUI for making them available in other VMs?
Those are the two windows that pop up during the process. I must assume that PersonalVM immediately removes it after attachment for some unknown reason.
It remains a real pain in the rear when the Qubes Devices fails to use the same designations as the command line. I only got ~xvdi, so which one is that and where’s there rest?
Since QD shows all drives and I wanted to detach from personal and try again, I detached (unmounted?) from personal. Something happened and I may have deleted it from the list all together. It is no longer there, but still shows in dom0. Is there a way to refresh the list?
Obviously, I am having a bit of trouble learning to navigate and/or use this new environment. There is enough difference from normal distros to cause this confusion. I’m afraid that I need to step back and start over with this issue.
You can attach the whole disk or just separate disk partitions to the qube.
For example, you have disk /dev/sda in dom0 with partitions /dev/sda1 and /dev/sda2.
If you attach the whole /dev/sda to the qube then it’ll be seen in the qube as /dev/xvdi with partitions /dev/xvdi1 and /dev/xvdi2.
If you attach a single /dev/sda2 partition to the qube then it’ll be seen in the qube as /dev/xvdi without any partitions.
Each new attached block device to the qube will have name in alphabet e.g. /dev/xvdi, /dev/xvdj, /dev/xvdk etc.
It seems that you’ve attached a single partition of the disk to your qube. If you want to access other partitions then attach them to the qube as well. Or attach the whole disk to the qube.
