I’m just curios how/when does KDE releases within qubes rolls out. Perhaps someone in particular is responsible for them?
Is there any info on when can we expect version 5.25?
Stock KDE from fedora repo should generally be working well on QubesOS. There’s a package to customize kde to be more qubes-specifc ( like colorized window borders ), and the new application menu will replace the Kickoff launcher of KDE.
Personally I’m using KDE 5.27 on fc37 dom0, and there’s almost nothing I can complain about, except there may be some missing icon on the panel.
Can you please tell how you installed the latest version(or how to install specific version)?
I installed mine with sudo qubes-dom0-update kde-settings-qubes as docs suggest.
That should be enough to have the latest version. For confirmation you can see the version of plasma-workspace package.
Maybe I don’t get this correctly, but I thought plasmashell --version is giving me the right answer. I have 5.18.5. How do you check plasma-workspace version?
And besides, I know that floating panels are introduced only from version 5.25 and I don’t have that option.
If you are on Qubes R4.1, then that’s the latest you can ever get ( except you pull the source code and compile yourself
). Because 5.18.5 is the latest version in fc32’s repo. If you try Qubes R4.2, then fc37 dom0 has KDE 5.27.
