How do i remove nonfree in fedora
I added nonfree.
sudo dnf install
https://download1.rpmfusion.org/nonfree/fedora/rpmfusion-nonfree-release-$(rpm -E %fedora).noarch.rpm
My question is, how do i remove it? I could not find an answer right now. I just want open source, not non free…
edit: So i tried: sudo dnf remove rpmfusion-nonfree-release
That might have done it. removed everything… Don’t know of i need to use --purge or anything…
To quote the holy scriptures:
“I’d just like to interject for a moment…” :sunglasses:
That should do it.
Entirely up to you, but you should be alright in this instance.
If you’re still worried, you can always reinstall the template using the qvm-template (or qvm-template-gui) command in dom0 :slight_smile:
Thanks! I don’t read the bible…
But my name is Don Verdean. :slight_smile: Long time ago now! I once almost found the pillar of salt. Lot’s wife.
