How do I get this AI Tor Scraping Tool Robin to work on a whonix-workstation appvm?
Robin: AI-Powered Dark Web OSINT Tool:
In an unrestricted user session I installed and created the docker container successfully but when i run it, it says: Did not auto detect external IP. / Please go to https://docs.streamlit.io/ for debugging hints. / [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 10; recommendation warn; host / [warn] 9 connections have failed: / [warn] 9 connections died in state connect()ing with SSL state (No SSL object)
It works for normal os users but I have been stuck on this for days to no avail. If it can’t be helped would you please refer some other tools similar to this one that you might personally use.
You may find this topic on the Whonix Forum relevant, especially the last post:
Note that the Docker page on the Whonix Wiki is currently incomplete, but that status may change very soon:
