How do I get GNOME applications to follow the XFCE appearance settings?
I am having a hard time getting GNOME applications like Nautilus to use a dark theme. Has anyone had success with this?
gsettings set org.gnome.desktop.interface color-scheme 'prefer-dark
The command no longer works since I have Fedora 40 with XFCE.
In Fedora-4x-xfce templates all the gnome stuff was removed. So if you still want do work with, you better should install Fedora-4x templates. But I have no clue, how long they will be appear in future versions of QubesOS…
The -xfce templates are more lightweight than their non-xfce pendants.
I know about the switch to XFCE. What I’m not sure about is why the GNOME settings don’t apply after downloading applications like Nautilus.
I’m afraid, you (also) need a “GNOME Settings package” - just only Nautilus and/or Drives or other GNOME tools are not enough. But I’m sure - if you’re using a / the Fedora-40 template, all will (still) be included there for you.
I’m not using the Fedora-40 or Fedora-40-XFCE packages. I am using Fedora 40 Minimal. I downloaded the gnome-control-center package, but it refuses to start with the error message: Running gnome-control-center is only supported under GNOME and Unity, exiting.
Could this be an indicator of my main problem?
Based on the message, you need to install GNOME in the qube to use gnome-control-center:
  • dnf group list -v --available | grep desktop does not list GNOME as an option.
  • sudo dnf group install "Fedora Workstation" has conflicting packages (firewalld)
  • sudo dnf group install "GNOME Desktop Environment" does not yield any result.
Could it be that for some strange reason GNOME is fundamentally broken with Fedora 40 Minimal?
Thanks, I was able to install GNOME with this, but when I try to start the GNOME Display Manager service, I get the following error:
sudo systemctl enable gdm.service
Failed to enable unit: File /etc/systemd/system/display-manager.service already exists and is a symlink to /usr/lib/systemd/system/lightdm.service.
At this point, I honestly don’t think it’s worth the effort. However, if someone is able to successfully install a minimal GNOME setup (say, just Nautilus) with dark mode enabled, I would be very interested.
