Sorry for the noob question.
I am able to create a zip file by right-clicking the folder. But gives no option to include a password. Is there an easy way to do this?
(I am trying to compress my Download folder)
you need to do it using the command line
zip -r --encrypt archive.zip Downloads
You should read that about zip encryption Are password-protected ZIP files secure? - Information Security Stack Exchange
Hi - I should have said 7z. I meant to say 7z but i meant zip in a generic sense.
How do I create the archive with the password?
With 7z, you can create an archive with a password using this
7z a archive.7z Downloads -p PASSWORD
Thank you very much. You are very helpful.
