How do I change screen res of a StandaloneVM?
Good day everyone,
Is there any document or guide about changing screen resolution of a StandaloneVM? I installed a Debian-10, because I do not want to dual-boot. However the window is fixed, and I could not figure it out.
Thanks,
Finch
Did you install the Debian manually from an .iso file? Do you have any particular reason to use a StandaloneVM instead of AppVM with TemplateVM? In the latter case you would not have such problem. Also, a StandaloneVM cloned from a preinstalled Debian-10 qube should also have no such problem.
You change the resolution just like you would in a standard install -
Settings-Display, select new resolution -
the window will resize to the new size.
thanks.
