I had a fedora 36 based standalone VM on R4.2 and I decided to upgrade it to fedora 40. To do the in-place upgrade I used the dnf --releasever= distro-sync --best --allowerasing command 4 times. After upgrading to fedora 38 I decided to restart and everything was functioning correctly. The problem came after I did the 38->39->40 upgrades, after a reboot the VM would fail to boot. Decided to try different kernels on the Qube Manager settings but that didn’t make any difference. Tried a volume backup revert but I guess that was too late as the VM was restarted many times before I found out about it.
Is there anyway by which I can recover from this situation and fix the VM?
Also in general what would be the optimal strategy for doing these kinds of in-place upgrades of standalone VMs such that data is safe other than cloning the VM (which I should’ve done)?
